Ever since updating to the latest version of the theme, I’m unable to change a post to the video styles even after following the directions of ensuring it’s in format – Video and a ‘featured video’ url added. The post remains the same default style. I also noticed that with the other style types, the “featured image” stays pinned to the post even when I select style 5 which should not have a featured image present.
I’m trying to use Style 10 for all of my posts (the one with the video on top) but it’s not working. I’ve tried clearing my cache and nothing works. Any ideas?
edit: also, when I do change it to a video format and try using Style 10 and add a video URL, the video is put in the “Default” style location which is what’s happening to all posts since the update. I’m also using the child-theme if that helps.
edit 2: I’ve also tried forcing a site-wide “Style 10” selection from the theme panel under Post Settings. The theme doesn’t seem to be respecting the selection since the update. I do not have a third party editor installed (no bakery, no gutenberg) just the TD composer.
edit 3: Also, if post style 5 is chosen, I shouldn’t see a featured image appearing at the top of the post under the headline, but it’s still showing up now.
mario118.
Unfortunately in Newspaper v9.7.3 there is a problem between WPBakery and tagDiv Composer, I recommend you to use a previous version -> https://forum.tagdiv.com/topic/important-new-update-newspaper-9-7/ until will fix the problem.
If you need other version of Newspaper theme you can send us an email at contact@tagdiv.com and we’ll provide you the version you need.
