I am trying to get rid of the revolution slider plugin so I added a slider with codings along with h align but it doesn’t align at center/middle.
Kindly check https://hiideemedia.com/services on PC to see what I am talking about.
Using HTML and CSS codes, a slider is placed at the top beside an image. I want this slider to move to the center of the column. Like they should both be aligned to the middle vertically and horizontally.
pls, how can I achieve that???
Hello @hadharm!
You can add a custom class to this block from Composer and add to that class a text-align:center; -> https://prnt.sc/n9BFA7GBn9ES
OMG I have always achieved this with vertical-align as middle in other composers.
ohhh you misunderstood what I asked. I am not talking about placing the slider in the middle horizontally. I want to place it in the middle vertically.
I also noticed now that more in footer menu is not opening/working. pls kindly recheck at hiideemedia.com thanks
Hello @hadharm!
Contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
We will check and try to help you!
