Issue with Column title
In version 12.6.6 you introduced new Column title shortcode that replaced old shortcode as a “simplified for a better structure”.
The new shortcode seems to have an issue.
1. Create a page with a new Column title shortcode
2. When logged as WP admin, test headings in SEO Pro Extension in Chrome, https://marketingsyrup.com/
– The column title will be shown like this:
< H2 >
/* custom css - generated by TagDiv Composer */ .tds-title-simplified{ margin: 0; transform: translateZ(0); }.tds-title-simplified > .td-element-style{ z-index: -1; }body .tdi_66{ text-align: left; }
– Other titles on the page (from flex blocks for example) are normal < h2 > Title name < / h2 > etc
See screenshot.
Thank you
Please go to the theme panel -> block settings -> inline css and disable the option to minify the CSS, clear the cache and check after.
Testing on dev site.
Inline css is not enabled.
No cache plugin installed.
Thank you
I can confirm that the issue occurs when the Aggregate Inline CSS is disabled. This obviously should not be happening.
Please inform your developers
Thank you
  • This reply was modified 1 year by Alex.
I will inform the developers about this issue.
Have a great day!
