Issue with "drop in more" on tagdiv composer
on my site https://11contro11.it/ the main menu (the black one) double is size every time i load a page if i active “drop in more” in tag div composer. It seems to resize after page load.
How to fix that? I have to use this funciton because menu have a number of voice to long for some devices. Thanks.
From what I can see there is an admin-ajax problem too -> https://i.imgur.com/E6zn7Pl.png this may be the menu cause too.
Please verify the console for error while saving the settings on the Theme Panel, usually it displays a 403 or 404 error.
If you don’t use a security plugin, please ask your host about this, maybe you have a security module which blocks this.
If you use a plugin like Wordfence please set it in learning mode.
Let me know the results!
thanks for the reply.
I checked many times in DevTools but i have no errors in console in page and on save setting page in theme panel. Infact your pic is strange, my megamenu load correctly for me. Anyway i refer to this strange behavior https://imgur.com/a/tgPsQC4
Sorry, I was thinking that you have other problem. Indeed the menu from your website is resizing, what you can do is to use a strong css like this one:
<style>
.wpb_wrapper .tdb_header_menu{
display: inline-block;
</style>
Set it in Theme panel> Analytics like this -> https://i.imgur.com/aXMj6mW.png
This should fix the problem.
thanks but your solution not works. I leave the code so you can test, anyway it was already inline-block. Is something else.
Please send us an email at contact@tagdiv.com and provide admin login, as well as cPanel or FTP if possible. We will take a look. Include a link to this topic in the email.
i send the email 4 days ago. No reply for now. Have you received it?
Sorry, is look that your website get in our spam -> https://i.imgur.com/KmmkYd2.png
We’ll answer as soon as possible!
in last email you say “in next update the problem will be fixed” but in the last two updates issue is still present.
Also i notice if that activate “DISABLE ARTICLE SCHEMA” theme still produce breadcumbs and hcard schema. With Yoast SEO for example i have double breadcumbs schema now.
I just checked again the problem with drop in more option on header menu and for my is working correctly -> https://www.screencast.com/t/71inAhy0
If the option is set like this for schema -> https://i.imgur.com/cg1JAkD.png then you’ll use only the schema from Yoast SEO, if is like this -> https://i.imgur.com/YOETGqx.png you’ll have both.
thanks for reply.
You have to insert more items (creation of two lines without it) for correct testing the mu issue.
For breadcumbs and hcard, i have already set the option to remove schema. Remove all others but not this two.
Indeed if you have more elements then the problem is still there, I think that our developers messed this and made the fix only for the classic problem, sorry for the inconvenience, I also reopen this bug on our list.
I also tested a post to check the breadcrumbs and hcard and now are displaying only once ->https://i.imgur.com/9NO2Axr.png if there is still a problem our you have some questions, let us know!
