Issue with featured video format and smart lists
All of a sudden the posts with featured video started messing up, see example:
http://todosobrecamisetas.com/2015/06/oficial-adidas-messi15-cleats/
And the smart lists are no longer working either. See example:
http://todosobrecamisetas.com/2015/05/adidas-2015-anthem-jackets/
Yesterday it was all fine, what could have caused it.
Please help! Thanks.
Please disable all plugins leave just Visual Composer active, clear cache and purge your files if you use CDN, also please disable all css/js minification and check again if you still have this issue. You have some errors in the console and also ajax pagination(that’s why you have issues with smartlist) doesn’t work – http://screencast.com/t/4vTI8nJte51
