iSSUE WITH FLEX BLOCK 1 – NO POSTS SHOWING
Kindly refer my website https://ayurvedafordiabetes.com/. At the top right corner, at flex block 1. No posts are showing where in category filter, i have selected “All Category” and in sort order, i have selected “Random Posts”. I can share my username and password of wordpress if required.
snapshot
Please check in “General” tab if there is any offset set for the block, if there is an offset remove it- https://i.imgur.com/j89cxbZ.png – https://i.imgur.com/RQ0wDxA.png
From where do i get the “general tab” settings. image link shared by you is not working.
First edit the page with tagDiv Composer – https://i.imgur.com/qbNfpm4.png then select the element then in the left sidebar the general tab will be display, https://i.imgur.com/KBeQmnD.png look for the offset, if you have a number there, remove it.
