You can only modify the footer with TagDiv Composer if you go to a page where it is assigned and edit that page with TagDiv Composer, and then you will have access to the footer also.
Also, it is normal to appear right there with no settings because those settings are for the default footer templates which you can not edit with TagDiv Composer. For example, if you will select there a default template you could see the setting on, but only for them and not for a PRO footer which is a cloud template.
