Recently my images have started to disappear from the website, stuff like featured images etc (http://www.invernessgigs.co.uk). I can not figure out what is going on, but as it has been happening across browsers it is concerning me, Any advice?
I have inspected your website and I saw that your images work as expected, without any problems. -> https://www.screencast.com/t/daGlNaX0UTT Clear all the caches and check the results.
I have checked your website again and I see that your featured images are working fine but it seems that they appear to be loading slower. Also, I have checked your source page and I saw that you are using such untested plugins which might interact with the theme core files and causes a lot of unknown issues. Try to disable all of these, leave just to active only the tested plugins and check the results. Clear all the caches and check the results. Notice that by default, the theme should not have this type of error and also, no image should disappear.
Hope this helps!
it appears to be jet pack that was causing the issue, strange no one else has noticed it
