Issue with images
Hello
I have a template for posts with the item: Single Post Bg Featured Image. The size of the image is “full” and 600 height, so I prepare the images of the posts for 1900×600.
If I do this I can see the image in a good proportion like here.
But if I set the “fixed image” option to do parallax style the image becomes with zoom like here, ¿How can I solve it? In the case, it doesn´t have a solution, which would be the best size for the image to show as the first example?
Hello !
The fixed image options is the option which will make your featured imaged fixed and you can scroll through it.
I know which is the function of the fixed image, but this is not my question.
This function makes zoom on the images as I said in my issue with images also…Can you read another time my question please and answer to my questions…..
Hello !
We have replied via e-mail.
