Hi there.. I am using a frontpage template using TagDiv Composer.. I have also installed the Mobile Plugin/AMP.. But when I go on the Mobile, the image from the template is not responsive and it is truncating.. Pls see attached images.. How do I rectify this so that the Mobile version serves a responsive image..
https://www.shippingandfreightresource.com/wp-content/uploads/desktop.jpg
https://www.shippingandfreightresource.com/wp-content/uploads/mobile.jpg
Ok so I have to come back to this.. I am NOT using Mobile Theme because it creates too many complications on my side.. So right now I am using non-mobile theme which works very well..
The only issue is that I have a hero image on the site homepage.. This obviously is set for desktop size.. Is there a way I can serve a different image if the device used is a mobile so I can customise the image, or is there a way to make it responsive.. Everything else I am happy with..
If you are using the single image element, then you can adjust the height and width per viewport – https://i.imgur.com/7GsmzkK.png each option that has a left border when you check a viewport offers the possibility to change the settings for that view port.
