Issue with mobile "sometimes" showing all code blocks.
This morning I pulled up a link on my phone to look at our website. The site was a default blue, with the menu option, but all code blocks, eg. [tagdiv]. I scrolled to the bottom of the page and clicked, “View full site” and everything was fine. I then shut down and restarted my phone to retest, and everything looked fine.
This happens intermittently. I was reading through the theme documentation to decide if I should use the mobile theme feature, but I’ve designed the home page entirely with the Page Content Builder. If I understand correctly, the mobile theme will not work in this case.
How do I trouble shoot or rectify this issue?
Hello therealshaunproulx,
I suggest you make a new clean install to another subdomain for testing via FTP way, remove all of the untested plugins, clear all the caches and check the results. If you have some additional customizations which can break the theme layout you should disable all of them and check the results. By default, the theme works fine and the menu mobile returns good results.
