All of a sudden the block for newsletters is no longer working on my site and is just showing up as code. You can see the issue here: https://imgur.com/a/8c9V5AA
It’s on my homepage and footer.
[tdn_block_newsletter_subscribe title_text=”Subscribe to our newsletter” description=”VG8gYmUgdXBkYXRlZCB3aXRoIGFsbCB0aGUgbGF0ZXN0IG5ld3MsIG9mZmVycyBhbmQgc3BlY2lhbCBhbm5vdW5jZW1lbnRzLg==” input_placeholder=”Your email address” btn_text=”Subscribe” tds_newsletter2-image=”5970″ tds_newsletter2-image_bg_color=”#c3ecff” tds_newsletter3-input_bar_display=”row” tds_newsletter4-image=”5971″ tds_newsletter4-image_bg_color=”#fffbcf” tds_newsletter4-btn_bg_color=”#f3b700″ tds_newsletter4-check_accent=”#f3b700″ tds_newsletter5-tdicon=”tdc-font-fa tdc-font-fa-envelope-o” tds_newsletter5-btn_bg_color=”#000000″ tds_newsletter5-btn_bg_color_hover=”#4db2ec” tds_newsletter5-check_accent=”#000000″ tds_newsletter6-input_bar_display=”row” tds_newsletter6-btn_bg_color=”#da1414″ tds_newsletter6-check_accent=”#da1414″ tds_newsletter7-image=”5972″ tds_newsletter7-btn_bg_color=”#1c69ad” tds_newsletter7-check_accent=”#1c69ad” tds_newsletter7-f_title_font_size=”20″ tds_newsletter7-f_title_font_line_height=”28px” tds_newsletter8-input_bar_display=”row” tds_newsletter8-btn_bg_color=”#00649e” tds_newsletter8-btn_bg_color_hover=”#21709e” tds_newsletter8-check_accent=”#00649e” fb_pixel_event_name=”Lead” embedded_form_code=”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” tds_newsletter=”tds_newsletter3″ tds_newsletter3-btn_text_color=”#ffffff” tds_newsletter3-btn_text_color_hover=”#ffffff” tds_newsletter3-btn_bg_color_hover=”#ffa256″ tds_newsletter3-btn_bg_color=”#2d5463″]
Make sure that the theme plugins are enable -> https://i.imgur.com/7EdWYIz.png then the Newsletter should be display again.
Let me know the results!
I am having the same problem with the newsletter block not displaying on the site. I’ve checked the code and it’s there.
[tdn_block_newsletter_subscribe title_text=”Subscribe to our newsletter” ... etc
I have also checked that the plugin is activated, and have also tried deactivating/reactivating it.
I have also been following the instruction you provided here for integrating with Mailchimp: https://tagdiv.com/tagdiv-newsletter-plugin/
Hi tomreeve, is this plugin enable on your website https://imgur.com/7EdWYIz ?
If yes still have the problem, please provide some more details about the way you implement the code in newsletter block.
Hi Calin, thanks for your reply. Yes, both of those plugins are enabled.
In terms of implementing it, I simply dragged the block into a column in TD Composer. The block was not visible in the layout but the settings box was, so I completed some of the info and saved it. It was still not visible.
However, when I preview and load the page, the newsletter block appears briefly and then disappears. I have tried it in several different positions on the front page with no luck.
Here’s a snippet of the code with the newsletter block in it (hope it helps).
Thanks, Tom
[/td_block_text_with_title][/vc_column_inner][vc_column_inner width="1/3"][td_block_categories_tags post_count="yes" custom_title="Focus categories" header_color="#0087b3" id_filter="7,6,2" order_by="count" items_padding="0px" block_template_id=""][tdn_block_newsletter_subscribe title_text="Subscribe to our newsletter" description="VG8gYmUgdXBkYXRlZCB3aXRoIGFsbCB0aGUgbGF0ZXN0IG5ld3MsIG9mZmVycyBhbmQgc3BlY2lhbCBhbm5vdW5jZW1lbnRzLg==" input_placeholder="Your email address" btn_text="Subscribe" tds_newsletter2-image="922" tds_newsletter2-image_bg_color="#c3ecff" tds_newsletter3-input_bar_display="row" tds_newsletter4-image="923" tds_newsletter4-image_bg_color="#fffbcf" tds_newsletter4-btn_bg_color="#f3b700" tds_newsletter4-check_accent="#f3b700" tds_newsletter5-tdicon="tdc-font-fa tdc-font-fa-envelope-o" tds_newsletter5-btn_bg_color="#000000" tds_newsletter5-btn_bg_color_hover="#4db2ec" tds_newsletter5-check_accent="#000000" tds_newsletter6-input_bar_display="row" tds_newsletter6-btn_bg_color="#da1414" tds_newsletter6-check_accent="#da1414" tds_newsletter7-image="924" tds_newsletter7-btn_bg_color="#1c69ad" tds_newsletter7-check_accent="#1c69ad" tds_newsletter7-f_title_font_size="20" tds_newsletter7-f_title_font_line_height="28px" tds_newsletter8-input_bar_display="row" tds_newsletter8-btn_bg_color="#00649e" tds_newsletter8-btn_bg_color_hover="#21709e" tds_newsletter8-check_accent="#00649e" embedded_form_code="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"]
This reply was modified 6 years by
tomreeve.
For me this code is working if I set it inside the page in code editor -> https://i.imgur.com/aBpd8ZQ.png -> https://i.imgur.com/Qw2IaHi.png
Also if you want I can take a look on your website to see from where comes the problem for you, but first make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv plugins (theme plugins), also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
If there is still a problem, you can send us an email at contact@tagdiv.com and provide admin login, as well as cPanel. We will take a look. Include a link to this topic in the email.
