Post title color not changing when the background is dark in Post template 3, 7, 8.
How to change that color when I use these three templates.
Here is the post link.
https://www.gadgetheadline.com/download-lenovo-z6-pro-stock-wallpapers/
Screenshot: https://prnt.sc/nnwqua
If a general color is set in the theme panel the post title color will not change automatically, that color will always apply to all the post templates. But if it’s left on default it will change when needed – http://prntscr.com/no8na9
If you want to keep the general color from the theme panel, but change it only for templates 3, 7 and 8, you could use a code like this in the theme panel custom CSS section
.single_template_3 .post .td-post-header .entry-title,
.single_template_7 .post .td-post-header .entry-title,
.single_template_8 .post .td-post-header .entry-title {
color: green;
A setting to color the post title for each template doesn’t exist, you could try this suggestion.
Thanks for the suggestion. Default Post Title Color is the best option.
