Issue with Post Template Layout – Elements Not Aligned to Edge
I’ve noticed a layout inconsistency between two posts on my site, even though both use the same post template.
In this article, the format appears different: everything beneath the article image is inset from the sides (i.e., not aligned to the full width, as expected):
https://perspektive-online.net/2025/06/der-hungerstreik-beispiele-einer-revolutionaeren-kampfform/
In contrast, this article displays correctly, with elements extending properly to the edges:
https://perspektive-online.net/2025/06/veteranentag-protest-gegen-die-werbetrommel-fuer-den-krieg/
Could you help me understand why this discrepancy occurs and how I can ensure consistent formatting?
The problem seems to be related to the caption set on this image https://perspektive-online.net/2025/06/der-hungerstreik-beispiele-einer-revolutionaeren-kampfform/ use set some html code and this is not close and is backing the template. Please edit the template and check the text and code from the caption of image.
