Hello Support Team,
I am experiencing an issue where some posts are not appearing in their respective categories. This problem does not affect all categories, but it does affect some of the more recently created ones. I have verified the following:
– The categories are properly created, and the URLs are correctly structured.
– The problematic posts have the correct categories assigned to them.
An odd behavior I encountered was when attempting to get one post to appear in its category; instead, another unrelated post showed up.
Please note that I am not using any caching plugins, and I have tested the URLs across multiple browsers to rule out browser-specific caching issues.
It is also important to mention that the website is currently in the development stage and is not live; it is being accessed via an IP address.
I would appreciate any guidance or assistance you can provide to resolve this issue. Please let me know if you need any further information or access to assist in troubleshooting.
Thank you for your time and support.
Best regards,
Aris
You can customize the category template. For the category template, please use posts loop; if you have set a posts loop then will display all posts in this category or you can use Flex Block/Big Grid Flex and set the filter to “Category -Current category” => https://i.imgur.com/7P99qx0.png and this is why the block will display posts for each category. So, please check the settings.
You need, as I said, to filter the first block to Category -Current category” => https://i.imgur.com/7P99qx0.png or delete the block with right-click.
The post is not displayed because there is an offset post on the block https://imgur.com/dJ0iFQu
Hi Anamaria,
I’m having the same issue. My settings were already the same as you recommend, but to no avail. Instead I get a complete mess that doesn’t display the one post in the category properly. This is the only category I’ve added to the site in more than 2 years… something clearly changed. Happy to give you guys login access if need be.
https://www.exhaustnotes.com.au/riding-guides/
Cheers,
Mark
Hi moose86, if is possible please contact us via email at contact@tagdiv.com and provide a link with temporary access – https://www.wpbeginner.com/plugins/how-to-create-temporary-login-for-wordpress-no-passwords/
