Issue with Tables – Mobile View
Hi, I normally include tables in my financial posts. Sometimes the tables has more than 10 columns.
When i am visiting the post on mobile, only partial column on table is shown. There is no slide right option to see the full table.
Example link(access it on mobile): https://wealth18.com/nre-fixed-deposit-rates-comparison-nre-fd-rates/
In my previous theme, the user could just slide the screen and was able to see the full table.
How cam i fix this for newspaper mobile theme.
Hello !
At the moment in order to fix this issue you will have to add a class manually to your table as you can see here: https://prnt.sc/r0jgj8 ; https://prnt.sc/r0jgof this can be done by editing your post in HTML mode: https://www.screencast.com/t/nocNMpZ1JO
