Issue with Taxonomy Filters Disappearing in Flex Loop
I have a question about how Flex Loop works with taxonomy filters. Here is the page I’m currently testing:
https://francegallcollection.fr/tous-les-vinyles-de-france-gall/
This page uses the taxonomies Formats, Chansons, Collections, Labels, Pays, and Types d’éditions (In french). I have added the corresponding slugs, and they are working correctly. For each taxonomy, I have enabled the “Multi” option.
When I select the term “LP (33 tours)” in Formats, all the other filters disappear.
My question is: is it possible to keep the other filters visible and continue refining the results?
For example, after choosing “LP (33 tours)”, be able to select an additional filter such as a term from Chansons or any other taxonomy?
Right now, as soon as I select “LP (33 tours)”, all the other filters disappear and the filtering stops there.
I think that you want to have something similar to the filter from this demo – https://demo.tagdiv.com/newspaper_job_hunt_pro/jobs/, then just make sure that you set the filters like this – https://i.imgur.com/BTtHHTI.png, make sure that the option Hide empty terms is not checked.
Yes, exactly: the checkbox was indeed enabled and now the filter itself works correctly.
However, there is still an issue with the counter (see my post on the same topic here:
https://forum.tagdiv.com/topic/request-enabling-ajax-filtering-for-cpt-ui-taxonomies-in-tagdiv-composer/).
In this example, I selected EP and SP, and there should definitely be values greater than 0 because those records do exist. Yet the counter still shows 0, which suggests there is something wrong with how the count is being calculated.
https://imgur.com/a/ikSnnbg
Indeed, there is a problem with the counter; I have issued a notice for our developers to check it.
