Issue with the fonts customizer
Hi guys, congrats for the great work.
I’m having an issue when I try to change the fonts. It keeps loading and it never ends so I can’t customize any fonts.
Can you tell me what could be causing this?
Please check the theme system status and make modifications to the parameters mentioned in this guide, if necessary
You could ask your hosting provider to make them for, as they might have a recommended method in this matter. Insufficient PHP memory can be the cause for this issue.
After making the changes, everything should work properly. Please let us know if there still is a problem.
