i can not seem to save any change i do in theme panel for my theme,, if i want to change ad in top or sidebad to another one,, i does not seem to save or update the changes
can you help , the link below
http://kolelnas.ly/
Please make sure that the parameters from system status have the values indicated in our documentation: https://forum.tagdiv.com/system-status-parameters-guide/ Also check the browser’s console while you’re trying to save the settings. Usually there should be a 403 or 404 error in console which refers to admin-ajax.php file.
The theme makes many requests to admin-ajax.php and file the security module from your server may treat it as a thread. In this situation that file is banned and the theme can’t access it anymore. Try to contact your host provider and ask him if you that file is banned or if there is any firewall on the server which may block the request.
