I posted this in the comment section of the theme on themeforest but no one answered me. Hoping for more success here. Ever since I updated the template 2 days ago, I have these “wp_booster error” messages in certain places in my site and now the footer copyright portion is missing!
These two errors are present directly beneath the author box within every post:
wp_booster error:
td_api_base::mark_used_on_page : a component with the ID: tdc_state is not set.
wp_booster error:
Missing parameter: ‘file’
These three errors are present within the footer block:
wp_booster error:
td_api_base::mark_used_on_page : a component with the ID: tdm_sub_footer_template_1 is not set.
wp_booster error:
td_api_base::get_key : a component with the ID: tdm_sub_footer_template_1 Key: file is not set.
wp_booster error:
The path of the template id: tdm_sub_footer_template_1 not found.
Hi all,
After you make the update please check if theme plugins are active, usually tagDiv Composer will activate automatic but it needs to be checked, also if you are using cloud template update the tagDiv cloud library and activate it.
https://www.screencast.com/t/n2QCNJRfm
If there is still a problem, please provide some screenshots with the settings you are made for this.
