Issues after Uptdate V8 – Visual Composer Layout issue
Hi there,
I just figured out that after updating to V8, our individual Visual Composer Layout is not working anymore. Prior to the update, it was ordered 1/4 + 1/4 + 1/2, see here: https://www.dropbox.com/s/a7y3ddiiw9tanrv/prior%20to%20update.PNG?dl=0
After the update, with still the same settings, every 1/4 fills the full page layout, now. And on top of that, the image added by Visual Composer is now extended to the full width and does not change by any pixel restrictions. After Update: https://www.dropbox.com/s/jknxc39cagnr0ty/After%20Update.PNG?dl=0
Link to live issue:http://starzip.de/impressum
Thanks in Advance for your help!
Please go to your plugins section and deactivate the tagDiv composer. This is activated by default when the theme is updated. There seem to be issues in some cases when Visual composer and tagDiv composer are both active, so try deactivating it and see if the page is displayed properly.
Is the theme working without tagDiv composer? I thought this is a requirement for Newspaper 8 in order to work properly. But if I can deactivate it, this would probably solve all my issues. Please let me know.
You can either use tagDiv composer or Visual composer. When both of these are active in some cases there could be some issues. If you deactivate the tagDiv editor everything should be like before the update for your website, when only the Visual composer was available.
Solved by disabling tagDiv-composer. Thanks for your help!
