Hello, tagDiv team. To start, great work with Newspaper 8, it’s full of features and so easy to use. Love it.
I added some responsive Adsense ad codes within the paragraphs of my posts and the ads are overlapping with the sidebar. Sometimes when you refresh the page, the ads display properly but most of the time the ads overlap.
So far, I haven’t had any other issues anywhere else on the website.
Here is a link to my website, JuanMTech and here is a link for one of the posts with the issue, Getting started with the Raspberry Pi 3
The other question that I had is, is there a shortcode to implement one of the custom ads inside of a post instead of having to enter the whole Adsense ad code?
Here is a screenshot of the issue https://imgur.com/eWMOAp2
Hello Juan,
I have inspected your website and I saw that your Ad is not working good, sorry! Before achieving best theme results, you should check the following useful guide here -> https://forum.tagdiv.com/header-ads-adsense/ because there you will found all of the useful steps which have to be followed in order to achieve good results with the ads. If the problem is still there, you should consult the Google AdSense provider, tell the problem and request them some help because they should be able to provide a more accurate response.
