issues with Block 18
I seem to be having issues with block 18. When I use it the small images do not show.
You can see the issue here:
http://www.cgmagonline.com/homepage-style7/
Any help would be amazing!
Hello bfrye26,
Please make sure that all settings are activated from Theme panel like this: http://screencast.com/t/gDSKHS3tZ0i
Hope this helps!
Hi @bfrye26,
You can also try to disable all other plugins except visual composer and check if your problem does not originate from a conflicting plugin.
Let us know how it goes and if the problem persist please send us an email at contact@tagdiv.com with your login credentials and we will inspect this issue as soon as possible, also include a link to this topic so we know who you are.
I managed to sort out the issue. I just disabled and reactivated the theme and it seemed to work. No idea why, but hey, as long as it is fixed!
