Issues with blocks not displaying multiple columns
I’m trying to use a blocks to display three columns of thumbnails. This is what I see when I edit the block (block 5) in Tagdiv Composer:
https://i.imgur.com/b5gHdwJ.jpg
For some reason, when I save and view the page, all the thumbnails/pages are listed in a single column, like so:
https://i.imgur.com/i8NUcuk.jpg
Please Note..
(1) The page is 1/4 + 3/4. The left sidebar was added in the row with visual composer
(2) This problem occurs no matter which block I try to use. Block 7 would also be good, but the same problem occurs (listed in single column).
(3) This is still a dev site. I can give a temp URL if you like but I don’t want to list it on the forum.
Please try to avoid using blocks in such row layouts, the results may not be the best. Blocks should be used only in these row layouts
– https://www.screencast.com/t/IHeHtDFuXZ
This will ensure that they will always display properly
– https://demo.tagdiv.com/newspaper/block-5/
The other row layouts are meant to be used with multipurpose elements.
However you could try the flex block, this block is more flexible and could be placed in a 1/4 + 3/4
– https://www.screencast.com/t/jJaLRjST
– https://www.screencast.com/t/aPjXD2mhVpuk
The flex block worked beautifully — thank you!
