Issues with Yoast SEO Premium?
I have the paid Yoast SEO Premium. It has the ability to suggest old posts for internal linking. But before that, it has to analyze all posts first. The issue is that when I do that, it doesn’t do it. Yoast support has suggested that I switch to a standard WP theme to see if that resolves the issue, just to know if the issue if compatibility with the Newspaper theme.
Anyone else have similar experience?
By the way, I assume the Newspaper theme use custom post/page types?
I have Yoast Premium and the suggest internal linking feature works fine on my site.
taco_and_co,
Thank you. That was a confidence booster. So, I started deactivating plugins one by one to see which one may have been causing an issue.
The thing is, and I am sharing this, so others in the future may serve as a reference.
I have WP Super Cache installed, but currently it is disable from caching (plugin is activated). I deactivated the plugin, tried site wide analysis, nothing happens. I activated WP Super Cache again (but in its setting, the plugin is not enabled to cache), now it is working – the site wide analysis. Will wait for it to finish.
Please also contact your host and have them remove any hosting side cache as well.
