Hi, I just bought Newsmag5. I loaded it but I don’t see any of the utilities listed. It turned my old homepage into a horrible confusing homepage, and it doesn’t give me any homepage alternatives. How is this possible?
Please provide some screenshots and so on -> https://forum.tagdiv.com/homepage-build-set-2/
Sorry, even though the zip was uploaded correctly, Newsmag5 Themepanel did not appear in the backend, I don’t understand why. In the end, I restarted my computer and now it appears. Thanks for the reply anyway.
Sorry, but something is not working.
1)If I open a page and try to use TagDiv Composer, a “critical error” screen appears and it’s not possible to work, even though the plugin is correctly installed and activated.
2)If I try to use Prebuilt Websites (ex. Magazine) it does not display the homepage correctly, no sections appear, just a sheet of text. And there are no entries in the backend that allow you to modify it.
3)When I tried to install the Mobile Theme PlugIn, the entire site crashed and I had to restore to the last save, losing a lot of work done.
The site is up to date (WordPress 6.6.2). Why does NewMag5 not work?
This reply was modified 2 years by
paolamanciagli.
Hi paolamanciagli, Newsmag 5 works just fine for me. Maybe you have an extra plugin interfering or some custom settings from host.
If the problem is still persisting and you agree we can take a look, for this it will be need to contact us via email and provide a temporary wp-admin access to the website and a FTP or cPanel. Also, include the link of this topic to can identify you.
