Hi.
I have installed on my site (www.cronachedipuglia.it) plugin for Facebook comments.
This plugin it’s compatible with my wp version.
I don’t have a problem from desktop but if i open my site from mobile smartphone, i don’t watch space for Facebook Comments.
Why?
I have checked your site an did not found any issues with the plugin: http://screencast.com/t/FA5OWHI7OAE
Please provide more details as I checked your site with Iphone 5 and did not found any issues. What device did you use and what space you don’t see?
I’ve checked your site and noticed lots of errors and notifications in browser’s console: http://screencast.com/t/t5d1J8Zuc
I believe this happens due to a plugin so please make sure you also test this without using any plugins, leave just the Visual Composer plugin active and the FB comments plugin then test gain and also check your console for errors.
Also make sure you empty all caches and purge files if you use CDN host or cache plugins.
