First of all let me tell you that I had liked this theme in its Demo on Themeforest, so much that I immediately purchased it.
But real trauma starts now…This Tagdiv MObile theme needs many ‘Ifs’ & ‘Buts’ to run smoothly. However, I am still in love with this theme.
My Website- https://discovervibe.blog
Earlier my Homepage was not working, somehow I managed to make this work after so much diligence in the previous 60+ hours. Now it is not working on my posts , I have seen on Forum that this is the most common problem of the Website owners and this question has been raised consistently multiple times.
It is advised to may that they can disable the mobile theme on specic posts, But pls note I have around 200 Posts, how can I manage this?
In order to keep AMP Plugin activated, I have to use MObile Theme too. As AMP helps Publishers & Bloggers. Is there any way to either all of these posts work on Mobile Theme or is there any way to disable mobile theme on a Large numbers of posts.
Still I welcome if you can help me making this possible to make Posts appear with TagDiv Mobile Theme.
Pls revert.
Sudhir
I can’t see your mobile version at all.
Please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Make sure your plugins, WordPress, theme are up to date.
Hi, as advised I have deactivated all plugins except TagDiv ones.
However, I am using the Prebuilt site design TechNews. I don’t know how to save the settings of Home Page, thats’why I have not deactivated the TechNews Prebuilt site.
Also all posts which are visible on Home page, I have disabled the Mobile Theme on them, so that these could be visible. But once this theme will start working perfectly, I’ll again activate the MObile theme on those around 40 posts.
As I have deactivated the all non-Tagdiv Plugins, now Many posts at lets are not appearing on Desktop too.
Regards,
Sudhir
Please send an email at contact@tagdiv.com and provide wp-admin, so we can investigate this issue. Also, paste a link to this topic so we can easily identify you and please provide screenshots with the posts are not showing.
Let us know and we will gladly assist you.
