Hello, How are you?
I don’t know how o fix this problem SideBar I have done all things I knew to fix it but nothing works
When I put AD Adsense and RELATED ARTICLES in SideBar some of the article works good but most of the article show sidebar under end of article
You can have a look
Look at this is work good = https://beelightworld.com/tips-tricks/21-invaluable-kitchen-hacks/ (You will see post and ad in sidebar)
Look at this = https://beelightworld.com/health/12-things-eyes-indicate-health/ (here is the problem you’ll find AD in the end of article)
I hope to understand me and help me
I do not see any problem with the sidebar on your posts
– https://www.screencast.com/t/AV5NmMYy
– https://www.screencast.com/t/YmuUE31CWHa
That could only happen if you made modification to the theme files directly or used custom code. That is the cause in most cases. Or maybe some incompatible plugins or widgets.
Please note that if you reply in your own topic after the first message, it will place the topic at the end of the line.
We answer from oldest to newest, and try our best to reply as soon as possible.
