I need to install a javascript code from a company that handles our affilate links for tracking but I can’t seem to find where to place the code. Our old theme had a section that allowed us to place a code right before the </body> tag which is exactly what I need.
I tried placing the code in the Custom Javascript section on this theme but the company still says it can’t verify our code install. How can I do this? I need to insert the code right before the </body> of posts and pages.
Can you recommend where exactly in the header, and do you work for this company?
As Chris says, you can place it right before the </body>.
Sometimes, that doesn’t work for me, too. So, I use the “Add To Content” plugin for this type of stuff. The plugin places it, intelligently, in the right spot for you.
(we’re both participants, not Tag Div)
