JavaScript code below and integrate into the footer/end of body tag.
I am using Newspaper theme. How I can paste the following JavaScript code below and integrate into the footer/end of body tag of my website:
<script src=”//z-na.amazon-adsystem.com/widgets/onejs?MarketPlace=US&adInstanceId=c85c8855-aaf0-4059-b6eb-f49ba9614543″></script>
Usually you can add that to your footer.php file, or through a custom function hook, or plugin to add content to footer.
If I add in the Javascript here: Go to Newspaper theme panel> Custom Code > Custom Javascript
Then where this Javascript will be placed?
You can enter the custom javascript code in the theme panel dedicated section and it will be added in the footer section automatically. Or you can enter it manually in the theme files.
Please advise how to remove a javascript code or html code from the footer section or from body section.
Thanks….
If you entered code in the theme panel sections, then simply remove it. If you entered it in the theme files, remove it from there. You wanted to add the code mentioned, before the closing body tag, that is located in the footer.php file
– https://www.screencast.com/t/jyDtlEVHv0TQ
Try entering it there and check the results.
