JetPack and site speed
I hope I am thinking right. Jetpack has a lot of modules or plugins in it. So that should use a lot of server memory and page speed should be significantly decreased.
I wan’t to know which “modules or plugins” in Jetpack plugin I can deactivate so my page will work without any problems or which “modules or plugins” in Jetpack must be activated that page works proparly.
My regards
I think each part from Jetpack will decrease your speed, what you have to do is to deactivate all featured that you don’t need it from Jetpack and let active only what you need. You can make speed test to see how will affect the speed each feature from Jetpack.
Hope this help.
Thx, I disabled almost 9 jetpack features. Only thing which I am not sure is “Omnisearch”. Does Newspaper theme uses this search or it has own search widget?
I would like to disable “Omnisearch” if Newspaper theme doesn’t need that.
The theme doesn’t need that, definitely you can disable it.
Thanks for your message!
