Journal demo doesnt use same sidebar on home page as it does on single post page
I have recently installed the Journal demo onto my site – however the home page and single post pages are not using the same sidebar – they look the same from the demo itself, but if I make a change to the sidebar on the home page using the tagBuilder (say removing the author photo for example) that isnt then replicated on a single post page.
I bought the theme as I was under the impression that the sidebars were the same and I could have the same sidebar running across every page on my site.
Does anyone know if it is possible to have the same sidebar running across every page please?
I am new to all this, sorry.
I just install that demo and for mew is look the same as in the live demo -> https://i.imgur.com/QWkyMWs.png -> https://i.imgur.com/Aoeu7jE.png if there is a problem, please check with tagDiv Composer like this -> https://i.imgur.com/1hk1FYZ.png click on image and set the one you want -> https://i.imgur.com/pUdXzm9.jpg
Cloud template need to be edited using tagDiv Composer.
If there is still a problem, let us know!
Have a nice weekend!
Hi Calin,
On your first screenshot the sidebar says “Popular Posts”. On the screenshot of the single post page (2nd screenshot) it says “Recent Posts” – they are not the same sidebar 🙁
How would I go about creating a single sidebar that is automatically used on all pages please?
As I can see is like in our live demo too -> https://i.imgur.com/SYHsk6B.jpg so the demo is installing correctly.
If you want to have the same sidebar on entaier websitem then you can create it using tagDiv Composer or using widgets -> https://i.imgur.com/oAyuTvZ.png
If you are using widgets, you can assign it sidebar on classic templates templates like this -> for all posts -> https://i.imgur.com/stL2zFf.png individual -> https://i.imgur.com/ou6k9rR.png and for pages and cloud templates you can use tagDiv Composer and set the “Widget sidebar” element -> https://i.imgur.com/kdF2npr.png this can display the sidebar made in Appearance using widgets -> https://i.imgur.com/jpCfMXs.png
Hope this will help you!
