JSON LD, Code tweaks, Code Compression
Hi Newspaper Developers,
I have a few questions,
1. Jason-LD – How to Add Jason-LD data to all pages of My Newspaper Theme. Is there any template functionality where I add the Code once and it implements across my site, and, all new pages created, will have it automatically.
If you can suggest a plugin for the same, Except YoastSeo, I will be more than happy.
2. Code Tweaks– I intend to use and will always use Newspaper as a Blog Theme Only without any sample data. In that way What Can I delete from my theme files for example: Can I delete WooCommerce and bundled sample data and plugins. Will it break the theme. My aim is to make it light and efficient.
3. Code Compression – Can I compress PHP, CSS & JS Code across the theme, Before I upload it to my host. If yes then how and what tools/services you suggest for it.
That would be all,
Thanks for your interest
I await all insightful and implementable replies
Amit
Replied via mail.
