json problem
JSON.parse unexpected character at line 1 column 1 of the JSON data
Please provide more information about your issue, screenshots or videos and your website link in order to help you efficiently.
I can not access this link: https://www.screencast.com/t/cwbWtoEG
Please provide more details using the solution mentioned above.
Hlw plz my link check and plz problem solved
https://www.screencast.com/t/6DWDMd9ncBW
We provide a fix for this JSON error in the 11.3.1 version. Please update the theme and plugins. Note that some CSS settings from the CSS tab of the elements which you adjusted in the 11.3 version will be lost. A workaround there could be to switch the last revision of the page.
Thank you for understanding!
