Language load problem
Dear Support,
I installed vintage_choppers_store!
After set translations to Serbian I see change
but woo site is still on English!
Do you know what is problem?
Thanks in advance
Hello @platamun47!
In order to avoid misunderstandings, please provide more information(screenshots/video) about what exactly you need to achieve or what is the issue there.
Dear Bettina,
After load/set Serbian language in theme panel and when I klik on empty cart icon in main manu I have a popup message on English:
No products in the cart
All in this page is on eng lang not on serb lang, please check:
https://elektricni-bicikli.rs/checkout/
Thank in advance.
Hello @platamun47!
Do you use the tagdiv Shop? Then you can translate some phrases and words here: Newspaper -> Theme panel -> Translations -> Translations.
Dear Bettina,
yes, I use tagdiv Shop”
I have serb translate for “No products in the cart”
serb: Nema proizvoda u korpi.
But message is still on english…
BR.
Hello @platamun47!
It seems to be a problem there. I will add it to our investigation list. The fixes will be added in the next updates.
Thank you for understanding!
Dear Bettina,
How long time you need for update?
Hello @platamun47!
I’m sorry, but I have no ETA.
Dear Bettina,
Maybe I must install woocommerce language pack to resolv this issue?
Hello @platamun47!
As you wish. But, we will try to solve it as soon as possible in the next updates.
Dear Bettina,
Thank you a lot.
I’ll be waiting for the update.
BR.
Dear Bettina,
How you progress about update to resolve this problem.
Thank you in advance.
BR.
Hello @platamun47!
I have no ETA yet.
Thank you for understanding and your patience!
Dear Bettina,
Any update…?
Hello @platamun47!
I’ve checked, and it is still pending.
Please be patient!
Thank you so much for understanding!
OK, thanx!
Dear Betina,
any update about this.
thanx in advance
Hello @platamun47!
Every fix will be added in one of the next updates.
Stay tuned!
Dear Betina,
any update for this issue…do you have?
You can use the files .mo and .po to translate https://woocommerce.com/document/woocommerce-localization/
Viewing 20 posts - 1 through 20 (of 20 total)
