Language switcher on mobile posts does not work
if I click on my mobile site (see http://quirktools.com/screenfly/#u=https%3A//www.eronite.com&w=414&h=736&a=37) on a single post and want to switch it via menu to another language, it doesn’t work. It’s the WMPL plugin installed.
On the desktop theme it’s correct.
Any idea?
Thanks a lot,
Luke
It’s also correct if I change the language at the WPML language switcher in the footer…
Now this is quite an unusual issue. Looks like when I click on the drop-down arrow it refreshes the page, like a misclick on the current language menu item.
For me it works fine on mobile – https://prnt.sc/osimjj -> https://prnt.sc/osimgk
I found a similar topic about this issue here – https://wpml.org/forums/topic/opening-language-switcher-drop-down-causes-refresh-page/
You could try the javascript code mentioned there, in the theme or child theme functions file. Then check if the issue is solved.
