Hi everyone before newspaper updating i can see my latest post on homepage and category page but when i will updating my theme i will not seeing my latest post on homepage and category page
i can see my post when i change my php version but i need to change every time when i post a new post to see my post!
Please help me guys 🙁
The issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using a child theme or cache plugin, deactivate them, clear all cache and try again.
Also, please provide a screenshot of your last post and send us a link to your website to investigate the problem.
Hi mam,
i have all importent plugins that i can not remove please check my plugins
https://drive.google.com/file/d/1etc4PUrClyxE7GL60xeWZqQ28RObjNbl/view?usp=sharing
my website url: https://ardailymagazine.com/
Unfortunately, I can’t see your screenshot => https://www.screencast.com/t/nbpXJiDyuZ
Also, please check what version of PHP you have, we recommend version 7.3.
I verify, and the latest post appears on the homepage => https://www.screencast.com/t/HHjacbsuA
mam I used recommend PHP version 7.3.27
and yes my latest post appears on the home page because I change my PHP version every time to see my latest post on the home page!
please check my after posting home page and PHP
https://www.screencast.com/t/FpLG8FbH85Ks
https://www.screencast.com/t/vV241kha
https://www.screencast.com/t/d27zrDiPIV
When I changed my PHP then I can see my post on the home page
https://www.screencast.com/t/LjjX2mPr
https://www.screencast.com/t/AMYPHuas
like this every time I need exchange to see my latest post on home page
I am using newspaper theme on my 5 sites all sites have the same problem
https://coolmomsrule.com/
https://orangelifemagazine.com/
https://pinoy1tvs.su/
https://eepublishers.co.za/
Please solved my problem asap 🙁
From what I saw from the images and I checked the website I think the problem is due to the cache plugin you are using.
So, please do a test using only the tagDiv plugins, clear all cache(also from your browser) and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
Please make a full backup to all files and the database and contact us via email at contact@tagdiv.com and provide the following:
– wp-admin URL and credentials
– cPanel URL and credentials
Our team will take a look!
