latest posts does not work
The sort order feature that shows the latest posts does not work and does not show the most recently added posts!
1. post
https://www.hizliresim.com/aor4h8t
2. post
https://www.hizliresim.com/gnjjyy3
Block settings
https://www.hizliresim.com/ccczogv
As seen in the pictures, the last text I added is not visible.
I think that I know what the problem is, please edit the cloud template with tagDiv Composer -> https://i.imgur.com/j8YvKks.png click on the block and remove the offset -> https://i.imgur.com/dJ0iFQu.png let that field empty.
When I checked, I saw that the relevant field is already empty. Could this be a functional error?
The problem is in the sidebar structure
Please provide the link to your website.
blog.tolgademir.dev
The way it is displayed in the posts is correct because if you are on the current post, it no longer has to appear in the sidebar.
As you can see on the homepage, there are displayed -> https://i.imgur.com/mcRfPib.png
It seemed before, The content I added last does not appear in the relevant place, this is a very important problem for me
The most recently added content is Test 2, Test 2 does not appear in the most recently added part of the Test 2 content.
https://www.hizliresim.com/nbd78we
The post doesn’t appear in the sidebar because you are on that post, this is how it works, if you are on that post, it should not appear in the sidebar.
I have been using this theme for 5 years, the most recently added post appears last, logically this is how it is. Has this changed in any version?
There is the same error in the popular section of the footer.
Yes, this was fixed; most users requested this change. This was changed in the version 11.4.2 -> https://i.imgur.com/SY28fgX.png
