Latest posts are not updating in blocks, showing old posts, instead of latest one.
I think that I know what the problem is, please edit the cloud template with tagDiv Composer -> https://i.imgur.com/j8YvKks.png click on the block and remove the offset -> https://i.imgur.com/dJ0iFQu.png let that field empty.
Edit with Tag Div composer is not showing, I tried your mentioned steps, but unfortunately it is not working. Please find the attached screenshot.
https://prnt.sc/XhDdTHq2wOLD
You need to select the blocks.
If your settings are not saved, please check this topic -> https://forum.tagdiv.com/topic/tagdiv-composer-does-not-save-only-content-of-homepage/ and try the suggestions. Also, please check the cache, and clear/purge all cache.
