layout display Issue on my sidebar block
issue with my sidebar block layout. it is not display same as demo . the images are messed up
please check on my site http://www.kid.net
screenshot
http://snag.gy/KyRIq.jpg
also all my category page post image are messed up. it isnt display as demo page.
how do we get all these image crop automatically to match the post size ?
You need to regenerate your images thumbnails like this: https://forum.tagdiv.com/using-the-theme-with-existing-content/ then make sure you empty caches and purge files if you use cdn host.
yea. i have already regenerate all my images using thumbnail regenerate plugin. but nothing change so i make the post here
Debugging Information
Total Images: 126
Images Resized: 126
Resize Failures: 0
Also no CDN No cache plugin
imaged created but didnt updated to the themes. whats going wrong here?
its found in FTP but not under media library. anyone can assist me here?
  • This reply was modified 11 years by kiat87.
If your featured image is smaller, please note that WordPress doesn’t enlarge images and you will need to use plugin like Thumbnail Upscale to enlarge thumbnails: https://wordpress.org/plugins/thumbnail-upscale/ For upscale use a combination of plugins Thumbnail Upscale + Force Regenerate.
As you can see where you use images big enough to be cropped for module that you use, they are displayed fine(the thumb is created) – http://screencast.com/t/UE8fZveU – http://screencast.com/t/AEaV0BtIQI
But where you use a smaller image – http://screencast.com/t/TCucZmQSxwwx this is not enlarged(this can be only cropped) on modules so it is used at full size – http://screencast.com/t/evY8jlwQex
1. ok . so it will load the generated images from folder directly and it wont displayed in media library – dashboard ? we can only delete them in FTP am i right here ?
2. and whats wrong with this ? http://snag.gy/5sVC1.jpg (the trendy photo pic) its too large or didnt crop or generate properly ? is this load from the correct generated images as well or not ?
3. also for my category page the image covered the wording . either too small or too big. http://kid.net/category/baby/children/
1. I see that you solved the issue with thumbnails – http://screencast.com/t/4byhTVDZ4 You should have in media library all uploaded images, not thumbanils.
2. I guess it was a caching issue – http://screencast.com/t/rh6RZpM2e8 so please clear cache.
3. Did not found any issues on your category page, please provide more details and also clear cache.
