I’m having an issue with a module layout. For some reason, the pictures and the titles are not aligned. I have tried to rebuild but it’s always the same regardless of the image size and regardless of the column width expressed in percent or in absolut value. As you can see below, it also varies for those posts that don’t have any picture.
You can see the problem by accessing my site here: https://nordsip.com/asset-owner-geography/sweden-asset-owner/
Can you help?
best,
Aline
Hello Bettina and thanks for your response. Unfortunately, the images don’t change anything.
I’ve changed the layout so there are no images anymore but the problem persists. See here: https://nordsip.com/asset-owner-geography/denmark-asset-owner/
Could you please help?
Many thanks!
Hello Aline!
I see that you have no image element in those modules. Edit the modules and check again.
If everything is set up and you set the images as well, then make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
Let me know the results!
Hello Bettina,
Yes indeed, I have taken the images away and I wanted to show that the misalignment persists even without images. Hence this problem is not caused by images. Do you think you could look into it again? You will see that the titles of the modules have weird margins throughout the page, as they are sometimes misaligned and there is nothing I can do about it.
Aline
Hello Aline!
– admin url and credentials
I will help you as soon as possible.
