Lazy Load feature on AMP post issue
I use newspaper theme version 10.3.9.1 and if I activate the lazy load feature of theme, none of the images are displayed in my AMP version of the posts.
Is there a way to disable the lazy load of the theme on AMP post?
Hello !
Please try using this plugin: Enable jQuery Migrate Helper plugin
This should fix the issue that you are facing at the moment.
Let us know the result !
Thank you for the answer but this does not work. How can I disable lazy loading on amp page only? Or how can I handle this issue?
Hello !
We need to take a look and see what can be done there to see if a fix can be done.
– admin url and credentials
Our team will take a look !
Please note that at the moment the Support team is not 24/7 available. We answer the topics from Latest to Newest Monday – Friday from 08:00AM to 05:00PM GMT+2
