Lazy load images in flex block 1
Recent post images in our footer are not being lazy loaded. They appear to be using a Flex Block 1 with CSS background-image and I found no options in the cloud template to lazy load them. Is there a way to lazy load these images?
See the footer at:
https://marthasvineyard.bluedotliving.com/
Hello @bluedot!
We have this feature: https://forum.tagdiv.com/loading-image-effects/ and these effects for flex blocks: https://prnt.sc/cVQp9oG7bxd5
Hi Bettina, thanks for the response. We do have the image animation enabled in the theme panel settings, but images in the footer (flex block 1) are not being lazy loaded.
There are no lazy loading settings in the flex block 1 that I can see. Are you saying that the shadow setting you sent a screenshot of controls lazy loading? The settings I am seeing look different: https://prnt.sc/vLYXQrpvvOPu
Hello @bluedot!
Yes, you are right. They are completely different. I just showed you what we have in our theme. That setting is not different. Check my screenshot again.
To clarify: are you suggesting that if we use the image hover effects on a flex block 1, it should lazy load images? Or that there is no option to lazy load images in a flex block 1?
Hello @bluedot!
If you activate the lazy load feature from the theme panel, then the images from the flex blocks will have this effect too when you refresh the page.
Please check if the feature is saved as enabled in your theme panel.
Make a test and deactivate ALL plugins except tagDiv ones, also if you are using a cache plugin, deactivate it, clear all cache and try again.
I’ll have to give it a try with caching plugins disabled. The lazy loading feature is enabled in the theme panel, but the flex block 1 in the footer does not lazy load the post thumbnails.
Hello @bluedot!
It should work well for your flex blocks too.
If the problem is still there, then contact us via email at contact@tagdiv.com and provide the following:
– admin url and credentials
– the license certificate and purchase code
We will take a look and let you know what can be done there.
