Lazy load not showing images
Lazy load not showing images at all.
On mobile, after scrolling down images will pop in.
Even the menu images don’t how.
https://prnt.sc/25ql6kh
After scrolling down images pop in.
Setting:
https://prnt.sc/25qlnkk
I tried all 3 options.
  • This topic was modified 4 years by yonish3.
I just checked your website and now seems the images are showing => https://i.imgur.com/WHizDcg.png
Did you solve the issue?
Nop
I just turned it off.
The site is not functional when it’s on.
I can share access for you to test.
Please provide a secure place to share the credintionals.
Hi yonish3, I just tested on my install and for me is working correctly, so it may be something with our install. Did you test it using only the tagDiv plugins? Maybe this s a plugin conflict.
If you test it and the problem persist, please contact us via email at contact@tagdiv.com, include the link of this topic and provide wp-admin access. We’ll check it as soon as possible.
