I have a problem with the very low LCP score of my new site http://www.tabexshop.store, but I have not managed in any way to reduce the “rendering delay” time despite caching, applying various file optimisation solutions and despite various tests on the code.
It’s about the loading of the title and subtitle, <div class=”td-block-subtitle”> as far as I can see on the pagespeed report and I was wondering if you had a targeted suggestion to decrease this value which should be around 10% of the absolute LCP value and instead in my case is close to 80%.
Thank you for any help you can give me in this regard, I look forward to it.
Sincerely
Stefano Introzzi
What I can suggest if you use CDN, is to use this option from this guide https://developers.cloudflare.com/speed/optimization/content/fonts/
Ciao Mattia,
grazie per info, avevo pianificato per stamattina l’aggiornamento e spero possa arginare il problema anche se nel mio caso non si tratta di un immagine che comporta dei tempi di rendering elevatissimi ma del testo riguardante il blocco titolo – sottotitolo.
Ti aggiorno e grazie ancora per il suggerimento.
Hello Anamaria,
in the meantime, thank you for your valuable suggestion.
I tried the cloudflare route a few days ago but unfortunately the situation did not change and I had several conflicting optimisation conditions with the rocket cache plugin options.
In any case I will try again with the latest updates
Thanks again and have a nice day
