left and right sidebar
How could I have on my pages 2 sidebar one on the right and one on the left so the topic appears in the center between the sidebar
Yes, you can achieve that using tagDiv Composer, all you need to do is to set the layout of row in 3 empty column -> https://www.screencast.com/t/5bwDe1xdmwJA after that set the elements/blocks in them; add a widget sidebar element with the composer – http://prntscr.com/n9g3c3 – http://prntscr.com/n9g3fu and select the desired sidebar.
yes i found out how I could do my question is that the same sidebar will also appear in the articles?
You can chose each sidebar to show on article, and if you want to make sidebars for post as the one for the pages you can get a single post template from tagDiv Cloud Library and edit it
I need 2 sidebars on one article page. and your support website showing error: Error establishing a database connection.
It seems to be a temporary problem with our servers. Try again because should work now!
The easiest way to achieve to sidebars will be to import some homepages from tagDiv Cloud Library -> https://www.screencast.com/t/Kl28blB9O
