Left Sidebar position – Mobile problem
If you set sidebar position on the left, sidebar content will appear above normal content on mobile screens. Are there any plans to fix this issue? I find this to be a really big problem as it makes the left sidebar feature pretty much useless. I know you can hide the sidebar with css on mobile screens but then you can’t display sidebar ads.
Is there a way to fix this by placing code somewhere maybe?
This happens because the elements are render in order and the left sidebar comes first. On mobiles the elements are set to float:none and they drop one after the other. We have this issue on the list, we’re looking for a solution.
Thank you, Emil G.
