LIGHTBOX DOES NOT WORK
1. I have version 9.7.2 of Newspaper and I have this problem with lightbox.I have disabled it in theme panel but I have not had success
Has it been fixed already?
2. I would like to know if I can put more custom ads, since the subject only has 5.
3.Other doubt, a few days ago you manually corrected my social counter code because Facebook showed 0 followers, could It fail again if I continue updating the theme with later updates?
Hello !
1. Unfortunately yes, the General image still faces some problems. You will have to manually edit the images you will have to go into each posts: https://www.screencast.com/t/IfglxPJM
2. In order to add more Custom ad in theme panel you need to the file td_config.php from includes and td_block_ad_box.php from includes -> shortcodes
All you need to do is to go in td_config.php and add as many Custom ad you need -> https://www.screencast.com/t/4dNUZBpPYMr6 in this example will add 6 and 7. After that go in td_block_ad_box.php: https://www.screencast.com/t/y5qiaLPc3gb
Results: https://www.screencast.com/t/VAUJIqls
3. Unfortunately we cannot say for sure that the counter will face no issues anymore. We have made the implementation on the actual Facebook system. If Facebook decides to modify the system then we will have to re-adapt to it so it could take a short time to fix it again.
