'Limit post number problem' with 2 'posts loop' items on category page
Hi there,
I have another problem using the Newspaper ‘Cloud Templates’. I’ve created a plain category template which have 2 different ‘posts loop’ items. They are divorced by a ‘Call to action’.
In the first Posts Loop, I’ve set the ‘Limit post number’ to 1.
In the second Posts Loop, I’ve set the ‘Limit post number’ to 8 with an offset of 1.
Strange enough, both Posts Loops on the front-end only shows 1 post.
How can I fix this please?
Hi there,
Sorry to be so impatient. I’m stuck in creating my templates for now and it seems there’s a another, related issue. It looks like I also can’t have 2 times a ‘Popular categories’ block on my website. I have one ‘Popular categories’-block on the right of my Category template and one ‘Popular categories’ in my Footer template.
Can you help me please?
Thanks a lot! 🙂
Hi Roularta, for the moment we do not recommend to set two posts loop on the same page/template, please use a flex block or anther block, because most of the settings from the first loop element will be set for the second one.
If is a pro demo you can use tagDiv Composer to change one of the Popular categories block and replace or edit it with other block -> https://i.imgur.com/owIgJ4P.png
Thanks for the help Calin! I changed the ‘Posts loop’ into a ‘Flex Block’ and there are no problems anymore 🙂
